查看: 10500|回复: 6
请教一下各位在CMD窗口下输入ipconfig/?出现的信息都代表什么意思????
发表于 2010-11-15 22:28:58 | 显示全部楼层 |阅读模式
Microsoft Windows XP [版本 5.1.2600]
(C) 版权所有 1985-2001 Microsoft Corp.
C:\Documents and Settings\user>ipconfig /?
USAGE:
    ipconfig [/? | /all | /renew [adapter] | /release [adapter] |
              /flushdns | /displaydns | /registerdns |
              /showclassid adapter |
              /setclassid adapter [classid] ]
where
    adapter         Connection name
                   (wildcard characters * and ? allowed, see examples)
    Options:
       /?           Display this help message
       /all         Display full configuration information.
       /release     Release the IP address for the specified adapter.
       /renew       Renew the IP address for the specified adapter.
       /flushdns    Purges the DNS Resolver cache.
       /registerdns Refreshes all DHCP leases and re-registers DNS names
       /displaydns  Display the contents of the DNS Resolver Cache.
       /showclassid Displays all the dhcp class IDs allowed for adapter.
       /setclassid  Modifies the dhcp class id.
The default is to display only the IP address, subnet mask and
default gateway for each adapter bound to TCP/IP.
For Release and Renew, if no adapter name is specified, then the IP address
leases for all adapters bound to TCP/IP will be released or renewed.
For Setclassid, if no ClassId is specified, then the ClassId is removed.
Examples:
    > ipconfig                   ... Show information.
    > ipconfig /all              ... Show detailed information
    > ipconfig /renew            ... renew all adapters
    > ipconfig /renew EL*        ... renew any connection that has its
                                     name starting with EL
    > ipconfig /release *Con*    ... release all matching connections,
                                     eg. "Local Area Connection 1" or
                                         "Local Area Connection 2"
发表于 2010-11-15 23:12:47 | 显示全部楼层
ipconfig——当使用IPConfig时不带任何参数选项,那么它为每个已经配置了的接口显示IP地址、子网掩码和缺省网关值。
ipconfig /all——当使用all选项时,IPConfig能为DNS和WINS服务器显示它已配置且所要使用的附加信息(如IP地址等),并且显示内置于本地网卡中的物理地址(MAC)。如果IP地址是从DHCP服务器租用的,IPConfig将显示DHCP服务器的IP地址和租用地址预计失效的日期(有关DHCP服务器的相关内容请详见其他有关NT服务器的书籍或询问你的网管)。
ipconfig /release和ipconfig /renew——这是两个附加选项,只能在向DHCP服务器租用其IP地址的计算机上起作用。如果你输入ipconfig /release,那么所有接口的租用IP地址便重新交付给DHCP服务器(归还IP地址)。如果你输入ipconfig /renew,那么本地计算机便设法与DHCP服务器取得联系,并租用一个IP地址。请注意,大多数情况下网卡将被重新赋予和以前所赋予的相同的IP地址。
如果你使用的是Windows 95/98,那么你应该更习惯使用winipcfg而不是ipconfig,因为它是一个图形用户界面,而且所显示的信息与ipconfig相同,并且也提供发布和更新动态IP地址的选项。如果你购买了Windows NT Resource Kit(NT资源包),那么Windows NT也包含了一个图形替代界面,该实用程序的名字是wntipcfg,和Windows 95/98的winipcfg类似。
总的参数简介(也可以在DOS方式下输入 Ipconfig /? 进行参数查询)
Ipconfig /all:显示本机TCP/IP配置的详细信息;
Ipconfig /release:DHCP客户端手工释放IP地址;
Ipconfig /renew:DHCP客户端手工向服务器刷新请求;
Ipconfig /flushdns:清除本地DNS缓存内容;
Ipconfig /displaydns:显示本地DNS内容;
Ipconfig /registerdns:DNS客户端手工向服务器进行注册;
Ipconfig /showclassid:显示网络适配器的DHCP类别信息;
Ipconfig /setclassid:设置网络适配器的DHCP类别。
发表于 2010-11-16 09:08:11 | 显示全部楼层
比较详细啊  很不错啊
发表于 2010-11-16 10:16:52 | 显示全部楼层
不错 值得学习学习...
 楼主| 发表于 2010-11-17 12:15:03 | 显示全部楼层
回复 2# 王梦瑶
    谢谢你的帮助,我非常感激!!!{:7_261:}
发表于 2010-11-17 16:19:20 | 显示全部楼层
不错 值得学习学习...
发表于 2010-11-20 15:26:42 | 显示全部楼层
study!study!
